-RJ- wrote:Ok here's my problem. I have a J30 hub with a 240sx bearing. I replaced the bearing and installed eveything back on my car and torqued the hub nut to 108 ft/lbs per fsm. Now my problem is that after everything was installed the wheel was hard to spin. I tried the other side and it spun fine. My question is should I loosen it a little, if so is that safe?
I also notice there is one part of it is harder to spin. As if I were to hold the 12:00 position and spin it clockwise, it would be harder to spin between 1:00 and 3:00 positions
I guess another question is the lock washer for the J30 and S13 the same? Im using the lock washer from the s13
Modified by -RJ- at 3:15 PM 2/23/2010
It's because the J30 and 240sx front hubs aren't the same, there is a small tolerance difference and that would be an issue. It's not designed for what you're doing.
Try this link: Go to definitive brake swap, and use a real S13 hub, they are cheap anyway:
http://www.tunerclub.net/forum...ilvia
x
