wheel bearing gone out again
deezlins
Car: 95 240SX SE
when i bought my 240 it had a bad front left wheel bearing, so i got it replaced just a little over a year ago. Well now it has gone bad again. Is there anything that would make the same wheel bearing go out repeatedly?
SmithSR
Car: 240sx
That's highly unusual assuming the spindle nut is torqued to spec.
ATTAIN hubs, brand new in box, bought from Alan when he was at SPL, and BOTH of the front bearings, upon applying spec torque, would creak and bind. Brand new bearings. I had to press out the new bearings and put in the bearings from my 4lug hubs. Luckily the 'old' bearings from 4lug hubs were nearly new anyway.
Moral to story is, stranger things have happened. At least you'll be a pro at pressing bearings when all is done.
ricebike
2002 Quest
2005 Altima
deezlins, did u purchase an aftermarket bearing from autozone/advance auto parts/ etc.?
i know they usually have a limited lifetime warranty if the ever fail again... just dig up the receipt & bring them to the parts counter for a free replacement.
deezlins
Car: 95 240SX SE
i got a new hub from a nissan wholesale online parts site, i cant remember which one though.
i was under the impression it was a sealed unit and you couldnt replace just the bearings and you just had to get a whole new hub? (S14 SE 5-lugs btw if that makes a difference)
SmithSR
Car: 240sx
No, the bearing presses into and out of the hub. Machine shops/auto shops etc have presses to do the job.
deezlins
Car: 95 240SX SE
I thought you could only press the bearings in and out of an S13 hub, and the S14's were sealed units and you couldnt do that?
hannibal
Car: Red Line to Glenmont
you can press out the S14 bearings like Smith said. THe catch is Nissan sells the hubs and bearings toegther
deezlins
Car: 95 240SX SE
hmm, well then does anyone know where i can get just the bearings?
SmithSR
Car: 240sx
Autozone, napa, schucks, etc... any parts shop any brake/general automotive shop or garage..
ricebike
2002 Quest
2005 Altima
oops, my bad; hub/bearing assemblies come w/ lifetime warranty where i used to work...
bearings from autozone for example... only a 30-90 day standard warranty
TIMKEN BEARING - FRONT WHEEL for a 1989 NISSAN/DATSUN 240SX Unit Price: $39.99 Core Value*: $0.00 Part No.: 510031 Weight: 2.35 lbs.
deezlins
Car: 95 240SX SE
i found my receipt and called the place and they said it had a 1 year warranty on it, and it expired 2 months ago. It started making noise and stuff longer than 2 months ago, and i thought it might have been the wheel bearing back then. So probably a little over 2 months ago i took it to the shop that replaced the new hub last time and i told them about what it was doing and the guy drove it and said it was flat spots in the tires. I did have flat spots in the tires, so i was like ok, i guess thats it. But then i figured out it was the wheel bearing. If i had known 2 months ago when they looked at it that it was the wheel bearing and not flat spots in the tire i could have called the place and gotten it replaced under warranty. Well i guess i'll go by Advance or Autozone and see how much the bearing is. Thanks for the help guys
Modified by deezlins at 2:58 AM 3/10/2005
deezlins
Car: 95 240SX SE
I went by Advance and Autozone and neither has the bearings or hubs.I guess i might just have to order a new hub again online or somethin.
