They said they could hear it howling when they had it on the lift... And I recall being able to hear it when i did the same thing as well......DAEDALUS wrote:Next time ask them how they came to that conclusion. Without some pretty nice equipment, they're guessing at best. Even if they used a dial indicator to check the bearing, it wouldn't tell them for sure the bearing's causing the vibe. Yes, it is possible. Just a little play you can't feel can become quite an issue at 80mph. But bad bearings usually come with other symptoms--by the time they start to wear like that they often make some noise. Probably lots of possibilities.
Good thinking, ill check that... Wouldnt surprise me that they may be bad considering the high power theyve been stressed with in past years.....texasoil wrote:Have you checked the axle half shafts to be sure they turn smooth and don't have a 'hitch' from a bad CV joint?Run-out on the wheel outer rim has to be kept low to avoid virbations. Typically well under 1/8 inch, preferably 0.010" or less. A bent wheel you can measure easily. A bent hub you can find by indexing the wheel around--measure rim run-out mounted in all 5 positions and see it it is 'with the wheel', or 'with the hub."
Interesting informaiton, i think what im going to do is get an opinion from my "mechanic" and we'll go from there...FarFetched wrote:I want to stress there are several different vibes out there!In case low pitch(slow) vibes corresponding to speed (not engine speed) look into half shafts(cv joints) tires, rims, bearings (will be noisy if shot). In case of high pitch vibs look into d-shaft, d-shaft support bearings, Rotoflex joint, defferential assembly(worn pinion) and pinion bearing. Also, transmission can produce vibs at high speed. Hard to diag the problem. In each instance there might be a fluctuating vibe (either mechanical or audible) or constant vibe corresponding with veh speed or speed of a component . Don't forget d-shaft is spinning very-very fast (if thransm is 1:1 gear ration, the RPM on the dash represent d-shaft speed). In OD speed is even higher!Vibes could be felt in steer wheel (shimmy), bottom of the seat, on the dashboard (put the palm of your hand on it). You need to determine what kind it is and go from there!A lot of peole can't describe the vibes for a proper diag!
Just a fresh info!Cheers!
This could be caused by bad bushings, yes?FarFetched wrote:That sounds like a subframe missalignment causing pinion to "walk" from its normal position. Worst case, diff bearings are "shot". There is equipment to listen to vibes, When I worked for Chrysler, we had a special tool with remote microphones (magnet) and sensors to detect vibes on VIPERS! Worked 99%. Takes time to set up but at the end worth every minute spent explaining it to a frustrated customer!I know vibes are "killers" of driving joy!Cheers!
