Wheel Balancing Is It Necessary
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Im getting ready to rotate my tires and I was wondering is it necessary to get them balanced if i feel no vibration or anything?I really dont want to pay for something that maybe unecessary so do yall get them balanced at each rotation or not?
erick.s
Car: 2008 Altima 3.5SE Coupe
You shouldn't need to. Generally you only rebalance when you get new tires or if you notice a shake. If you're good now, a rotation shouldn't change that.
Ferguson
Car: 09 3.5 SE Coupe
17 370Z Nismo
Once a wheel/tire combo is balanced you do not need to do it again unless you have lost a weight or have some unusual tire wear. Moving a wheel to a different spot on the car does not change the balance.
Colton92
Ferguson wrote:Once a wheel/tire combo is balanced you do not need to do it again unless you have lost a weight or have some unusual tire wear. Moving a wheel to a different spot on the car does not change the balance.
Thats what i figured but all of these auto shops say you need a balancing and I was like why would I need that.
And ferguson i like the car pic
louiebgt
Car: 09 Altima Coupe 2.5 S
What about balancing after installing Eibachs? is that necessary?
Ferguson
17 370Z Nismo
No... when you install the Eibachs you are not changing the wheel balance. Only balance the wheels when you change tires, lose a wheel weight (you'll usually spot that by feeling a vibration), or if you experience unusual tire wire (a long period of bad inflation pressure, improper alignment, flat-spotting a tire under severe braking without ABS, etc.). Once a wheel is balanced, no changes to the car, including rotation, can change the balance.
Ferguson
17 370Z Nismo
Colton92 wrote:And ferguson i like the car pic
I had to post one... Bmore-Coupe keeps bugging me!
Nothing special.... but I do love the car.
