offtheline »
https://forums.nicoclub.com/offtheline-u5954.html
Sun Jun 29, 2003 5:45 pm
I think the 16" wheels are around 11.7 lbs and the 17" wheels are around 14.6. I suppose that comparatively you would be adding more weight to each corner and would therefore "lose performance" but the reality is that you wouldnt be losing much. A 14lb wheel is lighter than the stock wheel anyways. I guess if the three pounds are a big deal to you, then wait on it. For me, if I could afford those wheels, I would go for the 17" wheel all the way. I asked a similar question before, and someone replied that a high performance tire is heavy anyways so you shouldnt worry too much about a 3 pound difference unless you are a hardcore racer and need every little bit of performance you can get.
