srdub-thttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=6e2cc6534862a0311049dcc8875c7fe2WHEEL AND OFFSET GURUS PLEASE HELP!Sat Jan 24, 2009 9:57 am
Postby
srdub-t »
https://forums.nicoclub.com/srdub-t-u52410.htmlSat Jan 24, 2009 9:57 am
wussup guys for some reason i really cant figure wheels out, no matter how much i search so maybe you guys can help..
i need a wheel that i can fit a 275 wide tire on an s13 without rubbing.. so after alot of searching i found that some people have rocked 17x9 with a +35 offset and had no problems putting a 275 back there... but now i found some wheels i like but there 17x9 +33 so my question is if i roll my fenders can i rock these wheels without rubbing?
Postby
AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.htmlSun Jan 25, 2009 7:03 am
Yes, people run 17x9 +15 will just a roll. At worst you'll just want to run some camber. 275 is pretty beefy for a x9 though. Is that the tire you want or is that the tire you have? Cause if you can choose your tire size, I'd go with around a 245.
Postby
srdub-t »
https://forums.nicoclub.com/srdub-t-u52410.htmlMon Jan 26, 2009 3:55 pm
500 whp horsepower on pump gas so 275 is the minimum i would run.. as far as the 9 inch wide with the +35 offset thats the size that will for sure fit back there in a s13. does anyone know any other sizes that would work.
Here's where I look for inspiration. The thread could use some cleaning up, but if you search diligently, you'll find some absolutely priceless 240 wheel fitment info...
