KFL »
https://forums.nicoclub.com/kfl-u1983.html
Wed Sep 22, 2004 4:54 pm
First off 95 240sx was involved in a curb accident. Replaced lower control arm and tein tie rods with spacer and new tension rod and installed agx/springs. Both sides are identical nothing bent other than tie/contrl arm/endlink snapped. The sway bar endlink is waiting to be replaced. I have to drive it hopefully to the alignment shop, about 25miles away. Everything is installed correctly, except the camber is way off and unbalanced on the car.Pulls to either side / \ I need some tips on getting the alignment anything close to spec driveable as of right now 20mph is the max or the tires start screeching. Also the sway bar wouldn't play a role in getting a alignment right? Just double checking as it only aids in turning.Tommorow I will attempt to get it driveable if not I'll have 2 ask a friend to aaa tow the car...its been almost 4weeks without the car finding parts and waiting for parts to arrive. I'm starting to lose it help! Any adivce/tips would help a lot.
