Hi all, need some advice on the suspension settings for a 2012 G coupe
Car has a KW Suspensions® 0.8"-1.8" x 0.2"-1.8" V1 Inox-Line Front and Rear Lowering Coilover Kit and is lowered by 15mm all round.
Just had new tires fitted 225/18/45 as the old ones were shot on the inside
I'm having real trouble getting the wheel alignment done as the alignment machines can't cope with lowered set up
Any ideas on what the correct camber / toe and caster measurements should be with this set up.
