bigE »
https://forums.nicoclub.com/bige-u7035.html
Sat Jun 05, 2004 4:32 pm
Ok, we most likley burnt up the #4 piston ring compression was 175-175-175-65. We are in the process of building another KA for obscene power handling, so I don't care to dump too much into this one. Here's a little background info on the motor, it's all stock, with 30k miles, a daily driver setup more so. We are pulling the head, and oil panoff within the next couple of days, the head will be getting a 5 angle valve job, and some mild porting and polishing work. Here's the dilemma, remove the bad psiton, hone the cylinder to smooth out any blemishes, then either replce the piston with one from the original motor showing 165 compression, or pull all 4, and re-ring them all, using from what I heard using the 99+ altima rings which are said to better?
What do you KA-T vets think?
Setup was t3/t4 .48ar/50 trim, 370's, huge fmic, SAFC2, WALBRO 255, timing at 17, AF's around 12.3, making 231 to the wheels at 7 psi
Appreciate the help guys
Eric
