hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Mon Feb 02, 2009 11:18 am
155 is a healthy motor. it sounds like to me one of the coil packs went bad. one way to test this is to have the motor running, and disconnect one of them at a time and see which doesn't cause the motor to change behavior. that one is your bad one. I, however, had tried this method and it didn't really help me at all too much. I borrowed coilpacks from my friend's sr and I found out which one was bad that way, and that is the way I suggest you go about doing it. it could also be likely one of your injectors went out but I am leaning more towards the coilpacks, as injectors don't seem to go out on nissans till 100k+
