I got this car a little over a month ago, it was falling on it's face around 4k, a slipping clutch, and a rough idle that was boucing up and down after warm up. I fixed the stutter (walbro pump & fpr) and installed a new clutch and JGY flywheel. Now its on to the idle problem a guy on these boards was trying to help me, but we decided to let everyone see.
Things I have tried:1. 2 Different MAFs cleaned2. Boost Leak Test3. 2 Different IACV/ACC solenoids cleaned (backside of manifold)4. Coolant Temp Sensor (thought what the heck 15 bucks)5. Clocking the TPS
During the clutch install my step-dad (mechanic) noticed some grounds not hooked up one was just the strap that connects to the manifold and the other was back by the igniter chip. The car has seemed to be trying to fix itself lately, by that I mean when I pull up to stop lights instead of the idle surging it goes up to 1800 and stays. Hope someone can help.Am I missing a wiring here? Others have 3, you can see I cut down in the harness I didn't find one, maybe I should go further, and I accidentally cut that wire and used a connector for now.Where does this vacuum line go? Can it just stay blocked off?To clarrify which sensor is this IACV or the AAC?
I have tons of pictures and multimeter and have been trying to read the FSM to see what wires I could check continuity, but the FSM is huge and I dont know where to start. Here are a couple videos of whats going on:StartUphttp://
www.youtube.com/watch?v=rtB1m1mc7fYIdle ... pFZZH3PBi8
