dattodude wrote:at 1500 rpm you've got some sort of air leak..
using some smoothish vice grips (or brake line , block off the air supply to the idle control block by squashing the hose that feeds the idle control block.
If the car won't start or idle without the idle control block, then it's the idle control block causing problems..
The AAC will likely be stuck off it's seat from gunk and funk.
But it could also be the throttle is also gunked up, worn out, or adjusted open too far by some wangan racer..
Ok.. I want to start by apologizing. I must have been smoking some crack or something because the idle doesn't go up when I unplug the aac valve. It goes up when I plug it in. I have spent the last couple days cleaning things and checking them. I have tested the coolant temp sensor and it checks out. I have tested the air bypass valve and that also checks out. I have cleaned up a couple very small vacuum leaks as well(the brake booster isnt even hooked up at this point. I have capped the line off to minimize variables).
I started it again today, this time again with the maf attached as close to the TB as possible but with the idle air supply still hooked up. and it seems to run better as far as Air Fuel numbers. But it is still "idleing" at ~2200rpm. And when I unplug the aac solenoid, the idle will drop to 1500ish but air fuel witll also drop to 11.5's or so.
I tried clamping off the supply line as suggested, and the idle will drop to around 1500 again but air fuel is crap as well at that point.
I really don't understand how this can occur. As the maf should be reading a lesser amount of air mass coming in from the decrease in RPM and the air fuel should be adjusted accordingly? This is really bugging the crap out of me. I cannot count how many of these cars I have trouble shooted before (almost all were due to vac/boost leaks) and I cannot figure this car out for the life of me.
If anyone has anymore insight on what I can do I would appreciate it. I also tested the idle switching circuit as spelled out in the FSM and that seems to be functioning properly as well.
Even though I don't hear any hissing coming from them, could the injector seals be bad? The injectors were replaced(with original injectors that ran the car fine a year ago) and I had to reuse the old seals. I don't see why this would be a problem but I am open to anything at this point.
Sorry this was so long.
