whats wrong with my engine???? NEED LOTS OF HELP!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
my motor will shut down on me whenever i miss shift to 3rd gear. (this only happens sometimes and when im racing or just punching my car) when my motor shuts down i would try to start it up it would just idile about 2 to 4 hundred RPM and then dies, when i try it wont start up until on my 3rd try it finally starts. now i dont know whats up with my engine. alot of people say that its my vacum hose and some say its a fuel cut off. HELP ME PLEASE!
VQMatt
Car: 95 Maxima
im going to say its fuel related, when you miss third do your rpms shoot up? try driving..somewhere safe where you wont get hit, no traffic or cars around..and instead of going to 3rd or 2nd go to neutral and rev where u usually do when you miss 3rd and see if it cuts off on u. There are 3 things you need for an engine to run. 1. Air(compression) 2. Fuel 3. Fire(spark) Since you are running, if it was a vacuum leak, you would know in the fluctuating idle, if you were not getting spark in all cylinders, you would feel it as well and it wont perform like it should. If you run out of fuel..it will die. Im not that knowlegable on this so if someone knows a lot about the fuel system feel free to correct me if im wrong and chime in on this one! Good luck man, I think its fuel, but I dont know how to fix it. lol
240sxvaj
well when it dies my RPM is about 6 to 7 thousand. somwhere around there. and when i rev my engine on the freeway it would not die. even when im in neutral. so im kinda
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
It looks like you're running out of fuel at those high Rs. Connect a temporary fuel pressure gauge and take the car out on the road to measure the fuel pressure when you rev the motor up to the higher RPMs.
