DryskalM3S13 »
https://forums.nicoclub.com/dryskalm3s13-u126900.html
Mon Feb 16, 2009 6:23 pm
the corrosion they mentioned can easily wear off at the connector end because of the continuous movement they see. ie: bumps, wind, rain, but the corrosion travels up copper wiring like a snake, it can easily be clean on the connector end and be almost eaten away inches or feet up the wire. if you can do a continuity check from one end of the connector to the other end, it should be >.05ohms (im sure the spec is more, but less is better). ive found semi-clean copper for over 2 feet then it turned into the nasty blue/green dust. corrosion is a *****.
