Whats Wrong???
SideWays Silvia
Car: Drifting, Tuning
Just finished up the swap, hooked everything up and went to try and turn it over and nothing happens, no inside dome light,no ding ding ding when the key is in nothing. Got new battery, still nothing...what else could it be? thanks
SpeedRacer1
Car: 1990 240SX, G35
Door chime and interior light = check the room lamp fuse in the driver side foot well fuse box. Then check all other fuses for good measure.
SideWays Silvia
thanks man, ill check first thing tommorow morning
S13240
Battery hooked up?:D
fiznat
Car: Grown up :(
its obviously somethin to do with your wiring... re check and find it!
SideWays Silvia
i found the problem.I missing the plug that plugs into under the fuse box. I cant find it anywhere either: ( It should be on the lower harness right?
thes14project
Car: Thinking my friend and I have mechanical skills
yea, the plugs for the engine fuse box aare on the lower harness. Did you use your KA lower harness? That's the easiest thing to do. Other than that, it could be stuck somewhere probably around the motor mount area. Also, if that doesn't work, then it's probably a ground.
