Whats Wrong?
SideWays Silvia
Car: Drifting, Tuning
In my 240 no matter how hard a shut the door, the door open lights stays on and the interior lights come on. If i pull it a little bit harder after i shut it, it goes off but when i let go it moves back. And when i lock the doors from the inside when i get out and shut the door they unlock automatically and i have to lock it with the key. What is going on??? please help lol
rico05
Car: 1992 RMS13 w/ CA18DET
Look inside the door jam. There should be a little black rubber plunger. See if that is stuck depressed in. That is the sensor for the door shut. Other than that, no clue.
89S13SILVIA
Car: CARS
you have to hold the handle to lock it and your door switch that tells that it is closed may be bad or worn out replace it
SideWays Silvia
thanks guys
Chingon
Car: 1991 and 1992 hatchbacks
have the exact same problem...and it's also in the drivers side, I'm thinking bad switch too.
