Whats up with the lower black grill?
msp
Car: 2008 Infiniti M35
Anybody know what the solid black plastic square is in the lower black grill? It apparently covers a pitot type tube. What does it do? Can it be removed?
maqueswell
Car: M35 Sport
Can you post a photo?
george926
Car: M35
why is that piece bothering you?! cause to me you can't really see it.. afterall it's black.. i took it off for the install of my ACC.. but i really dont see any reason to remove that piece..
but maybe you have a better reason to remove that.. LOL
George
tigerclaws1318
Car: 2006 M45 Sport
msp wrote:Anybody know what the solid black plastic square is in the lower black grill? It apparently covers a pitot type tube. What does it do? Can it be removed?
Your probably talking about the sensor for the adaptive cruise control. If you remove it then you'll probably get a malfuction cruise control light on.
M4T5
Car: 2007 Infiniti M45
If it is the rectangular dark smoked glass piece you are talking about....then you better leave it alone. That's the Adaptive cruise control sensor!It far from cheap to replace, repair, or adjust.
J
cam35
Pop it out from the bottom with a flathead scewdriver. It reveals the threads for your "tow hook" that should have come with your M. Get stuck in the mud, screw the tow hook into the treads and have a friend pull you out. Or the tow truck driver can use it to pull your disabled M on the flatbed tow truck. Look in your truck on the left side where the tire tools are located, tow hook should be in there.
FNAWSM
Car: Diamond Graphite '06 M45
^what he said :dblthumb:
