S13_RB25 »
https://forums.nicoclub.com/s13-rb25-u151727.html
Sat Oct 15, 2011 7:18 pm
Hey guys long story short, I sprayed some engine degreaser towards and around the oil pan! And after I washed it off and what not, it sat for the night, drove it next morning and my steering wheel started to shake around 23mph to 25mph! After and before that point its fine. Also what I mean by the shaking is up and down type movement. Its more of like a vibration, I guess the best way to describe it. On a side note when I pushed down on the front two struts, from the fender, the driver side one is stiffer compared to the passenger one! Would that have anything to do with the steering shaking?? I know it sounds like a noobish question but im pretty sure that is also is causing the drive shaft to get most of the vibrations!
Also it is a 93 s13 with PU motor and trans mounts! No modifications are done to the suspension! So what can cause these vibrations???
