ka24dave »
https://forums.nicoclub.com/ka24dave-u49278.html
Sun Oct 21, 2007 4:49 am
I got a 91 240 coupe with a redtop sr. mostly stock, only mods are a greddy profec b spec II EBC, fmic, downpipe, megan exh, hks ssqbov, (of course a walboro 255), and upgraded clutch. I have blown a few turbos before and replaced them no prob, but the last one i blew it looked like something was in the intake side blades and it chewed the blades down and caused shards of metal to get into my fmic (luckily it didnt get upstream the other side - it looked like it didnt get past the pass-side elbow hose of the fmic.) I may be wrong though becuase now the car (since the day i got a bad exhaust leak and the turbo blew) always bucks, pops, and backfires alot. if you granny the living hell out of it keeping out of boost it mostly drives ok, but then at times AND whenever you go into boost it feels like it has a miss and it sounds like a subaru from under the hood and my friend says the exhaust sounds like a turbo harley davidson.
the car often at cruising when heated to normal temp in any gear will sputter and miss not with every engine revolution (at least it doesnt feel like it) but every 50 foot or so it misses sometimes backfiring. my back bumper is covered in blackness so i know im running rich, but i also know there has to be more to it,
Ive already fixed the following problems on the car/or checked these things:
1. Oil pan dent fixed, pressure is nominal (abt 64psi cruising @3k rpms 5thgear.)
2. Exhaust leak from the turbo to mani-Replaced the gasket. HOWEVER i have a stud that stripped the threads in the block in the center underside on the manifold. and im almost positive its leaking (i need use of a smoker!) ...could this be my only issue?
3.I pulled my plugs and they are correctly gapped, the plugs not looking too rich or too lean. but 1 of them was a bit black, not bad enough to cause concern though.
also im not sure but i might have boost leaks as well...tried testing before using a can of computer duster, then i tried starter fluid....nothing happened.
I do not have a gasket on the elbow on the intake side that goes from turbo to the intercooler piping. but i never have had one there before either and it ran good...good enough to pull a 13.1 pass on 14 psi.
any help would be appreciated or any ideas
