I guess it does not work! Anybody know a fix for this?jamesblonde82 wrote:that makes the headlights go up and down without turning them on, so you can do things like change the bulbs out. does it not work for you?
The antenna is broken on most 240s. Unplug it like Loki said, or replace it with a n S2000-style antenna.BiXLL wrote:I also just found that my antenna does not go up and down. I can hear the motor running when I shut car off, but antenna stays up????
So even if I can hear the motor running, it is junk? There is no fix for it? What is S2000 style antenna?ishkabibble wrote:
http://www.locustom.com/shark2_kit.htmBiXLL wrote:What is S2000 style antenna?
It worked, turned lights on, hit switch, and turned lights off. They stayed up!GoinTopless240 wrote:Try turning on the lights on one position (parking) and then try the switch. You can then turn off the lights and the lights should remain up... just a thought... mine don't pop up any more, so I don't remember the correct sequence..
no! they are junk! I replaced my broken mast with a lot of trouble and the damn thing started acting up again a couple months down the road! XM, CDs or iPod FM Transmitters are the only way to gojamesblonde82 wrote:no the antenna is not junk! all you need to do is replace the mast. get your buddy over to turn on and off the radio. zerothread?id=187719
