whats this connector?
97s14pwar
Car: 97 240sx s14, 90 240sx
its a bigger gray connector with 8 pins, 2 pins have 12v with Ket on engine off, another 2 have about 6v. it looks like it branches off around the maf connector. the wires were cut off on the other side of the connector so im just trying to figure out what it does thanks]
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
show us a pic.
97s14pwar
[IMG][/IMG]
Modified by 97s14pwar at 6:22 PM 4/15/2008 there it is
Modified by 97s14pwar at 6:24 PM 4/15/2008
240z4u
Car: '95 Nissan 240SX
Sorry, didn't see the photo.
Modified by 240z4u at 5:44 PM 4/15/2008
Carl H
stuff that should be wired in during a swap, sounds like the wiring is half done...
97s14pwar
this one is a rectangle shape connector i have both male and female end, the female end of the wires have been cut off, i tried to copy a link to the picture
97s14pwar
pic should be working now
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
If this is for an RB25 (which it looks like it is), that is the plug where the grey injector power wire needs 12V power. Cut it there, strip it out of the harness, solder an inline fuse, and attach it to 12V power.
97s14pwar
but the car starts and idles? i thought the 12v source is suppost to go the connector that stationary right in front of the intake manifold next to fpr
Darius
The "connector that stationary right in front of the intake manifold next to fpr" is called something to the effect of "injector harness connector". The gray wire is the 12V power wire and the other wires are the ground for each individual injector to the ECU. The gray wire in the injector harness must already be connected through the plug you took a picture of because it wouldn't start if it wasn't. You can try disconnecting it and see if it fires up. It probably won't. The reason most people have to rewire the grey wire on the injector harness plug is because the other half of the connector pictured above is typically not in tact when a motorset is purchased. The other half of the connector is part of the chassis harness, not the engine harness.
97s14pwar
so should i unhook where i have the wire now, and hook it to that connector, or leave it be
Darius
Either way will work. I don't see why you would change it if it is working properly now unless you didn't like the look of it or something like that.
