whats the redline on a redtop sr?
corey240
Car: 1993 Nissan 240SX Base Drift Machine
so whats the redline supposed to be on a redtop sr and when should i shift when racing ect..
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
7500rpm
GTS4-R
Car: my feet
and the stock rev limiter is set at 8000rpm
corey240
So the stock redline, which is where i shouldnt push past, is 7500, and it is limited meaning it wont go past at 8k? sorry just tryng to understand it because this kid with a teg said on his gsr motor it revs to like 9k or somthing and with the jdm itr ecu it will revout to 11k, which he did for like a year, which is why he sold his teg with a blown head
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
7800 RPM is the fuel cutoff/limiter from what I've found/been told (could be 8000 though), but the JDM S13 SR cluster shows 7500 RPM as the redline so yes, you shouldn't rev past this and if you hit the cutoff/limiter, it stops revving. If you're going to rev this high with the stock head, you need some RAS, especially if you are going to do it with any sort of regularity on the track. I have RAS, but still only rev to ~7000 max when I run the motor hard. If you want to rev near the redline a lot (or past 7500) then you need to build the head up like ILikeMy240sx did so it can rev to 9k.
corey240
so it would be safe to say until get ras to keep it at like 6800 when shifting?
homeslicej2
That'd be fine. I mean you can rev it to the 7500 RPM limit, but you know the SR has problems with the rocker arms so yeah, I try not to rev mine to the limit too often and think that 6800-7000 is a good limit until you do something with the head. The t25 runs out steam before then anyway.
corey240
ok thanks for the help everyone
Sabot
since we on this topic how about an s14 sr? same?
CoupedUp
Car: 1993 Coupe
S14 SR is a T28 and flows more in the top-end, but remember guys at 13-14 PSI you guys are maxxing out the Duty on the injectors around 6200 RPM and starting to lean out.
