PROJECTRB240SX wrote:YEAH I'M LOOKING AT DOING THE ENTIRE HEAD AND TRYING TO GET 100 PONIES OUT OF IT.
I THINK WITH TOMEI 272'S, OPEN UP THE PORTS AND VALVES AS WIDE AS THEY WILL GO, POLISH AND BLEND THE RUNNERS, CLEAN UP THE CYLINDER DOMES, 3-ANGLE VALVE JOB, STIFFER/LIGHTER SPRINGS AND RETAINERS..... AND I SHOULD SEE THE RESULTS I'M LOOKING FOR.
PROJECTRB240SX wrote:WHAT ARE YOU DOING WITH THE OLD TURBO?
2fast4j00 wrote:These are the mods I have at the moment but not all of them are on the car right now. The engine is going in sometime this week hopefully.
1990 RB26 240sx hatch
Mckinney RB mounting kitBored and honed to 2.8 litersShot peened RodsSummit oil coolerSummit fuel pumpSummit fuel regulatorPT-67 GTQ trim turboDelphi 880cc injectorsApexi-Power FC with datalogit softwareApexi boost controllerApexi turbo timerBillon high flow low temperature thermostatC’s short throw shifterWiesco pistonsCustom metal head gasketKaaz 2 way LSDR32 front calipers300zx rear calipers300zx cross drilled rotorshawk brake padstokico shocksrsr coiloversgreddy radiator capgreddy oil catch canhks vpcInline pro racing intercoolerAutometer gaugesAutometer tachARP head and rod boltsFront and rear strut tower barsFront and rear sway barsRear mount battery kitKoyo radiatorBig Electric FanTwin plate excedy clutchHKS ssqv blow off valveHKS titanium muffler with 3.5" custom exhaustUpgraded timing beltTomei 11.5 valve springs and retainersTial 46mm HP wastegate
Ordering soon:S15 Vertex front end and bodykit17x9 and 17x10 Volk CE28N's (will be here in 3 months....BAH!)
rbsileighty wrote:With all that you have going on there and as much power you could be making... might want to add a driveshaft loop to the mix.
