InsanityInc wrote:I've never seen any KA dyno hold it's torque for that long, not even ones with different cams...
And my point is this:
You jumped into a few different threads claiming that the intake manifold was the culprit of all the KAs TQ drop and top end power loss.
Now we show you a dyno that proves that, as I said before, "it's not as bad as you make it out to be"...
My argument is that all the dynos you've been looking at, no ones gotten the combination right..."klattr1" has. Smallish-ish turbine housings like we all like to run on KAs flow OK, but not great...so the VE starts to drop quickly. "klattr1" runs a big-a** hot side on his turbo, and it lets the engine breathe up top, paired with the right cams, of course.
Here's a turbo dyno from my car at ~6psi...notice the TQ carries on to +5000rpm...
I attribute the decent VE to a dumped wastegate (less backpressure in the exhaust manifold), plus a .63 A/R turbine housing with a stage III wheel is not a restriction at that boost level...it becomes a problem at higher power level as illustrated in the dynos you posted above...and the TQ drops like you say.
But that's not from the intake manifold design.
My .02...
- Brian
