Whats the most cost effective solution for radiator/fans on an RB25 swap?
RideZX6R
Car: 1995 Geo Prizm (sweet beater)
2001 Tahoe 4x4
1990 Silvia Coupe
I want something that will work all year round for me... I know it's gotta be slim.Altima fans won't work like on an SR if I understand right.So what will? What have you guys used with good luck that won't break the bank?Thanks
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
What mods (if any) have you done to your engine?
I got an S-14 radiator (for Free!) and used that + 16" SPAL pusher (~$150). If you do this, you need to upgrade your alternator (Quest 110a) because the fan draws around 25a. Work on some ducting and voila!
Oh yeah, stock RB25 with FMIC and 3" exhaust.
RideZX6R
2001 Tahoe 4x4
1990 Silvia Coupe
l0nestar wrote:What mods (if any) have you done to your engine?
I have an S14 that I'm putting the motor into.I haven't even done the swap yet.I'm planning on buying everything I need first.I'll be doing an FMIC as well, it'll eventually be getting a GT35R, but not for a few months. I'll drive it on the stock T3 for a while.
pirate87
Car: 1997 Nissan 240sx SE
I bought some 16 inch e-fan off of ebay, mounted to my S14 radiator and have never had a cooling issue. I've run this setup all summer and in stopped traffic. The fan, if I remember right cost me about $45 new.
RideZX6R
2001 Tahoe 4x4
1990 Silvia Coupe
pirate87 wrote:I bought some 16 inch e-fan off of ebay, mounted to my S14 radiator and have never had a cooling issue. I've run this setup all summer and in stopped traffic. The fan, if I remember right cost me about $45 new.
wired it in as a pusher?
so ok ... whats all this stuff I read on Zilvia about the fans/rad having to be really slim then?
s14_sport
well its better to have your e-fans as pullers....thats why they say efans have to be really slim because since the RB engine is one big mofo there is hardly any space between the radiator and the front of the engine to fit fans. Using your fan(s) as pushers is not as efficient but having it mounted on the front of the radiator leaves you some room to have a really big fan. So it all depends on your setup.
RideZX6R
2001 Tahoe 4x4
1990 Silvia Coupe
s14_sport wrote:well its better to have your e-fans as pullers....thats why they say efans have to be really slim because since the RB engine is one big mofo there is hardly any space between the radiator and the front of the engine to fit fans. Using your fan(s) as pushers is not as efficient but having it mounted on the front of the radiator leaves you some room to have a really big fan. So it all depends on your setup.
Make sense.How's that black car sir?
s14_sport
hey man...the black silvia is doin pretty good. got the RB in and runnin pretty good. just got some more bugs to get out and gauges to mount and I'll be good to roll again. Been a long process, but, all worth it!
Abdo
Car: S13 RB25DET
Flex-A-Lite Dual PullersKOYO Copper SR20 Radiator
About 1-1.5 inch clearance from the pulleys with slight modification of the upper radiator support.
I have heard many good things about the Altima Fan setup too.
David_NISMO
Car: RB26DETT powered S13
S13 with RB26dett, with stock twinsI'm using a stock S13 radiator with two Hyundai puller fans. I have a hole cut in my front bumper.
I have no cooling issues for daily driving. If I start pushing the car for very long 30seconds or more I do start to heat up.
I am purchasing new coolant parts as we speak, but this set-up will get you by for quite a while.
Existing radiator $0Radiator hoses $152-12" Hyundai fans $20Water Temp Gauge $40
Being able to drive the car as-is, priceless.
lilskyline240
Car: 90 240sx w/ rb30det
also interested in ppls setups
RideZX6R
2001 Tahoe 4x4
1990 Silvia Coupe
s14_sport wrote:hey man...the black silvia is doin pretty good. got the RB in and runnin pretty good. just got some more bugs to get out and gauges to mount and I'll be good to roll again. Been a long process, but, all worth it!
Good to hear. As you can see... I'll be going the way of the RB as well
RideZX6R
2001 Tahoe 4x4
1990 Silvia Coupe
David_NISMO wrote:S13 with RB26dett, with stock twinsI'm using a stock S13 radiator with two Hyundai puller fans. I have a hole cut in my front bumper.
[img]
Well I want something that'll work in the long haul but not cost a billion dollars. Not something to "hold me over"
FriedEGs
Car: 1995 SE, Roast Beef!!
RB25DET.. S14
Stock radiator2x 10" Flex-a-lite pusher's ($150)Nismo thermostat ($65)
