whats the matter? (no current to dist.)
furple
Car: 1992 Nissan 240SX Fastback
my car wont start
all the fuses are fine and the ignition coil has current
but there is no current going to the distributor
how could I fix it?
Tuvara
Car: '93 240SX SE Fastback
'10 Sentra SR
Ignition Coil Wire, Distributor Cap, Distributor button* not sure if that's the actual term but its the thing that spins around to make contact with the points in your distributor to fire the spark plugs. Any of those would be good to start checking if your not getting current at the distributor.
Ekinchheng
Car: '93 Nissan 240SX Coupe
Tuvara wrote:Ignition Coil Wire, Distributor Cap, Distributor button* not sure if that's the actual term but its the thing that spins around to make contact with the points in your distributor to fire the spark plugs. Any of those would be good to start checking if your not getting current at the distributor.
Its called the distributor rotor, usually when you do a tune just tell them you need the cap and rotors for short. Also does the car crank and did you check if it has spark? Any fuel comming out (do you hear the fuel pump humming) when the key is in the "on" position?
dickie
Car: Killer Turtle
moved to correct forum and title changed to get you more helpful responses.
