brianw »
https://forums.nicoclub.com/brianw-u65970.html
Thu Jun 14, 2007 2:13 pm
FWD and RWD what? VQ35DE's?
If so, I'm not sure-- the required flywheel thickness and dimensions are probably slightly different due to input shaft length differences. You can use a 350Z clutch on a FWD 5.5 gen or later Maxima if memory serves correctly, if you have a flywheel with the appropriate dimensions.
If the FSM has the dimensions for the flywheels in them, you could compare and check...
Also, the crank position marks may be different between the two flywheels. If those are different, then you're pretty screwed. I've heard of some unbolting the crank position mark rings and swapping them over, but IIRC those are heat-fitted on and are difficult to get off. I could be wrong, of course...
