Whats the difference?
K240
Car: 1993 240sx
Whats the visual difference between the USDM SR20DE, and the JDM SR20DET, without the turbo, and turbo components?
K240
Car: 1993 240sx
BUMP
Nismo_Freak
Car: 89 Nissan 240SX
USDM SR = distributer
JDM SR-T = coilpacks
K240
Car: 1993 240sx
Well, that would work, except we dont have much parts besides the block and some odds and ends..., anything else?
Hijacker
Car: '92 240sx Convertible
'94 F-150
and the way they're mounted in the car. the USDM is transverse. not a big thing, but i do nitpick.
i don't believe the USDM Sr20s have a redtop valve cover, and the valvecover is of different dimensions, IIRC
K240
Car: 1993 240sx
tenkawa_akito wrote:and the way they're mounted in the car. the USDM is transverse. not a big thing, but i do nitpick.
well, it is out of the car, and the guy who sold it to my brother said the valve covers color was changed, it is grey, not red... Any more, cause i cant seem to make sure whether it is JDM or USDM.
Hijacker
'94 F-150
is the transmission still attached to the block? transverse trannies are way shorter than RWD trannies. Also, take nismo freak's advice on the distro thing. SR20DETs came with a direct coil on plug ignition system, so they don't use conventional spark plug wires. that should be the big flag warning is if it has a distributor and plugs or an electronic sensor (located on the front right of the valve cover) and coil packs. (there will be no spark plug wires)
K240
Car: 1993 240sx
no , the transmission is not attached to the block, and we dont have a coil or a distro, but we do have spark plugs, with wires attached...
Hijacker
'94 F-150
if you have conventional plug wires, then you have a FWD SR20DE. If you have a picture, I could confirm that for you.
K240
Car: 1993 240sx
i dont know how to post pics..., it has really long plugs, that go deep into the engine.
K240
Car: 1993 240sx
bump
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
:pface
dude, look up the SR20DET on google images. and then look up the SR20DE, or sentra V-spec motor...you'll see the difference
Dori Dori
Car: Cars of course
The pistons.
180crafter
Car: Nissan 240sx
Um... How about a turbo????? US sr20's never came turbo. Just look at the exhuast side and if the manifold is stubby and has a few round things, then you know its turbo. If it is long, then no its a USDM.
BTW.... If you ask a question like this, you are already over your head. Im sorry, but please sell your motor, do your homework and then try again.
I suggest the movie The Money Pit (Tom Hanks)... it will teach you a valuable life lesson.
Dori Dori
Car: Cars of course
He said he doesn't have manifolds.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
looking at a SR from the top
A FWD sr will NOT fit in a 240 without a bunch of modification. You would need so many parts off a RWD motorset you might as well just buy that and leave the FWD SR where it belongs.
gundamx_105
Car: silvia
j spec is correct, and also the spline that goes into the transmission on the rwd is bigger, the size of a ka24de. and the fwd is smaller.
i had to use a ka alignment tool on my sr20de, and the fwd usd sr clutch would not fit of course.
