whats the difference?
TurboSilvia7587
whats the difference between the zenki s14 sr20det and kouki s14 sr20det?
ILikeMy240sx
Car: SR Power
as far as I know all s14 SRs are mechanically the same.
Wiring might be different tho.
SpeedRacer1
Car: 1990 240SX, G35
The ECU and wiring harness's are different. The ECU plugs have different pins and will not cross over.
Engines are the same, MAFS are different but read the same. Just a bunch of useless stuff was changed.
The last model S14 K's MF-T was totally redone and put down 250hp with an IHI turbo, retuned ECU and some other minor changes. However that engine is basically impossible to get.
