whats the difference between s1 and s2 rb25's
jrb92se
Car: 1989 Nissan S13 coupe
ok as the title states im asking what the difference between an rb25det stage 1 and stage 2 are is it like o.b.d or something ive been searching i cant find anything i just got the car im new to the rb and i must really sound like it thx guys
Joe
S2 are newer (late r33's)no igniter chip (each coilpack has one, vs 1 for all)other small electrical differences*rumor* the turbo has a steel exhaust wheel vs the standard ceramic. no proof tho.
BigPar
Kamin wrote:*rumor* the turbo has a steel exhaust wheel vs the standard ceramic. no proof tho.
Does anyone ever say anything about turbos off of S2's that blow up at high boost? I hear and see pics of blown turbos, but what are they from?
jrb92se
when i bought the car he told me it has a s2 rb25 thats why i wanted to know the difference; is there any thing that i can look for on the engine to be able to tell ?
BigPar
well, like above said, look on top of coil pack cover between the valve covers. Sitting on top in the back should be a box. If there is a box you have a Series 1, no box = Series 2. Also check the MAF sensor and plug. 3 prongs inside the MAF connection = Series 2, 5 prongs = Series 1.
jrb92se
thanks man
jrb92se
hey dude i was lookin at my engine and on top of the black plate in between the cam covers at the back there are four screw holes does that mean the coil you were speaking of was there and has been removed ?
Joe
no, they used the same coilpack cover plate it just dosent have the igniter attached.
you have a series 2.
jrb92se
your abilities far surpass mine ; i am humbled
pignosedRB
Car: 1989 240sx
Is this the box that would make it a series 1 your talking about this is similiar to the RB i just got
digzsublime
Car: 95 S14 w/ LS1.
Yes. That that "box" is the ignitor. If yours has it. You have a series 1.
meet07
Car: 89 180sx rb25det
is there any benifit having a s1 or a s2, beside one being newer. Im assuming that there the same thing.
Cameron
Car: a 240
is there anyway to relocate that ignitor?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
meet07 wrote:is there any benifit having a s1 or a s2, beside one being newer. Im assuming that there the same thing.
S1 motors share more common parts like coils and cas, compared to the S2 which have a different style.
You can relocate the igniter. Just extend the wires to where you want to place it.
RB'd SX
Car: 98 240SX ,89 240sx ,08 sx4
is there any benifit having a s1 or a s2. does one have more hp than the other
TSL
Car: Nissan
Joe wrote:S2 are newer (late r33's)*rumor* the turbo has a steel exhaust wheel vs the standard ceramic. no proof tho.
All RB25 turbos have ceramic exhaust wheels.
RB’d SX wrote:is there any benifit having a s1 or a s2. does one have more hp than the other
1. S2 is newer.2. No.
I see this is an old thread...
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
also s2 along with retaining the ceramic exhaust wheel, it also has a Nylon(super hard plastic) compressor wheel, turbo is still a time bomb around 1bar. The nylon wheel was though of to make for a fast spool but no ones really tested it.
s2 can only use s2 ecu's, and s2 coil packs, because of the ignition relocation.
you can use s2 ecu on s1 but never use a s1 on a s2. rumored to short out the ecu.
both series use the one Apexi RB25 PFC, neo need a different PFC
something different about the intake cam angle sensor too that should be noted when upgrading cams.
hmm thats all i think that hasnt been mentioned that i know about.
Neejay
Someone also said that the fuel rail is different.
"the S1 is 2 piece inlet tube to the fuel rail, the S2 is a single piece."
I haven't been able to confirm myself though.
Coolwhip
Vendor
silviasgp06 wrote:also s2 along with retaining the ceramic exhaust wheel, it also has a Nylon(super hard plastic) compressor wheel, turbo is still a time bomb around 1bar. The nylon wheel was though of to make for a fast spool but no ones really tested it.
I've ran a S2 on a S1 ECU and the car has been running all year.
I assume your speaking about the cam angle sensor on the exhaust cam gear. Late S2's use a different CAS drive unlike the earlier and S1 motors that use a star and half moon key way.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
superspikky
Car: 1995 Nissan Skyline GTS25T series I
1986 Nissan 300ZX Turbo
2001 Honda Accord EX Coupe (modified)
i know this thread is old but i thought it be nice for to add. that the TPS sensors are diffrent on S1 vs S2
tight240
ECU's are no different, you can use S1 on S2 and visca versa. The ignitors are built into the coils, so the coils are not interchangeable. Thats the main differences plus a few sensor's and plugs are different.
meet07
If you have a series 1 and want to use a series 2 long block, what is needs to be swapped besides the obvious intake manifold,turbo header,injectors,clutch yada yada? I know they both have diffrent CAS? Do the cams need to be swapped out as well?
StricNyne
well inj are the same, so is the CAS for me at least if u have the huge plastic cas than you need the metal one, but biggest differance is tps, maf ( i think), and 100 percent the coilpack setup, u need new coilsetup without ignitor you could rewire whole thing which idk if its ever been done or just go with a series 1 harness you already got and use series 1 coil packs. if your changing blocks, and they are complete, all u gotta change is the harness and the coils, i have done this over and over again on my setup (rb26 harness which uses series 1 coils, and the metal cas, i used on rb26 harness and a series 2 harness) now tps plug your on your own cause i have a q45 tb and tps and i dont run a maf since i am on a map sensor, arent you the guy with the clean a** red kouki with the vsxx ? that car is sick u got ne new pics ?
flatrate
Car: S14 kouki
so will a series 2 CAS bolt on and plug in to a series 1 engine granted the series 1 engine has series 2 cams?
I have a good deal on a set of cams but there for series 2
flatrate
Car: S14 kouki
TTT anyone
Mfox
Car: 1992 240sx Black Sil-80
From my research and informant conversations from importers alike. The s1 and s2 engines are exactly the same, internal-wise..... The only thing that changes is the electrical bolt on components in the way it ignites combustion and how its read.
Coolwhip
Vendor
correct
Marahutay
Car: 1991 Nissan 240SX Fastback
Hey guys, I came across this thread from a Google search about the difference between the CAS on the series 1 and 2 longblocks, and I want anyone else who ends up here to know that the cams are not interchangeable due to the crank angle sensor. If you plan on ordering aftermarket cams make sure they match up with what series motor you have/the CAS you have.
Sorry if I'm breaking rules ressurecting such an old post but I know I can't be the first person who has ended up here from a Google search.
