Post by TomGreen » https://forums.nicoclub.com/tomgreen-u4577.html Mon Mar 22, 2004 12:48 pm
Post by p00t » https://forums.nicoclub.com/p00t-u5026.html Mon Mar 22, 2004 12:48 pm
p00t wrote:throttle bodies are exactly the same, the TPS attached is different i believe. A/T models have an extra "hard closed throttle position switch" and wide open position switch which is used for the transmission control. M/T dont need these two switches. the manual just uses the WOT button behind the gas pedal to turn off AC etc under full acceleration.
edit: whoops, to answer your question the A/T TPS should work on M/T cars, the ECU will just ignore the extra signals. but it will not work the otherway around, since the ECU/TCU needs those signals for transmission control.![]()
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
