whats the common problems
johnny7268
Car: 1992 240sx
I just bought a 1992 240sx as is, This is my first car. It doesn't run, I bought it from my aunt and uncle. When they bought it a year ago it was running. My uncle said something about the bottom end. What are the common problems with the 1992 240sx motor.
thanksJohnny
dropteam21
Car: 1990 240sx SOHC
can be a lot of things do you know alot about cars? what hapends when you try to start it? sorry i cant realy help you a lot i have a sohc but, with out knowing more i cant help maybe some one can. Is it leaking oil or water?
johnny7268
Car: 1992 240sx
Well this is my first car so I don't know too much yet, they took the vavle cover off and the battery out, I still have the valvle cover, can I just put it back on and put in a new battery and start it up to find out whats really wrong with it.
Johnny
P.S Thanks for the help
dropteam21
look to see if it has any thing on the head that will mess it up. Like leaves and stuff. Get a new vavle cover gasket and replace the cover. See if its got oil and coolent. I'd drain it and replace oil and coolent but this might be a wast of like 30$ if you need a rebild or somthing. Is it auto or 5 spd? good luck.
johnny7268
Car: 1992 240sx
it is auto, but i will convert it to 5 speed, once i gain a little more experience with it and once i can get it running, so you said i check the head for leaves and stuff, I'm new to this so, what is the head, after that i should drain the oil and the coolant and replace it, put the valve cover pack on with new gaskets. But what should i do about the bottom end, because my uncle said something about the bottom end being the problem.
thank for your help
johnny
dropteam21
well if it is the bottom end if you dont know alot yet I would not have you take the head off and start geting to the pistons and crank. the head is the thing your seeing on the top of the moter that the valve cover goes on. As far as what the pblem can be thers lots of things a bent rod bad berings hidro lock. but with out tering the moter down this is about the best i can tell you. You can take it to a shop but lol thats a lot of cash. I would go to napa kragan auto zone ext.. and get a haynes or othe brand of car maniwal ( yes i have bad spelling 39 kids in one class and 1 teatcher will do that to ya lol) and read the rebild and engen overhall part from front to back.But dont rip apart the moter after this it will just help you know more about what your working with. If you have any tools make sher evry thing is set on the car mainly the timing set is fine and the disributer is in then pull out a 27 mm socket (i think its 27 on my sohc so might be the same for you) put it in nutral and the big pully at the boutom of the car try to move it i have not realy looked at the engen bay so your fan might be in the way but if you can get it to move some you can rule out hidro lock also look around the moter for any holes in it .I was thinking yes dran the oil and coolent look for coolint to have oil in it and the other way around. If you have any freinds with engen know how i would have them come help. If it is somthing on the bottom end you may be looking at a rebild or a swap. but I would tryto see if you can get it to fire and find out what the problem is hope i helped if you got any more Q just ask we'll try to help.
johnny7268
Car: 1992 240sx
alrite man thanks alot, I will try all this first then I will let you know how it goes.. you probably won't hear from me until next weekend, i'll be working on it all week thou... thanks a lot man I really appricate it.
dropteam21
no problem looks clean in this pics i'm thinking about doing my car black with red but i dont knowlooks good and good luck.
johnny7268
Car: 1992 240sx
dropteam, man i just got the motor out today and i'mma gonna start the rebuilding process... it was a ***** but i'm excited...
infinity_218
Car: 1990 SOHC 240sx
I have found that two of the major problems with 240's is - coolant leaks into the cylinder. i believe due to common leaking head gaskets - the tensioners that were used on the timing chain/belt is made of plastic, which shatter, thus losing tension, and making your car not run.
i pulled and engine out of the salvage yard and both things were wrong. the dude trashed his car for a really easy fix.
