whats the cheapest way i can fix this dent???
CrC SIL80
Car: 1989 Nissan 240sx fastback
i need help on the chepest and fastest way to fix this dent???
sean@z1
Car: 1993 240sx
there is not a cheap way you chould pull the dent then hammer the panel with a block till almost straight. Then bondo it and sand and primer and paint
bersh240
duck tape.lighter.spraypaint.worked to seal a rusted out drain plug in the bottom of my car..or.. i cant really tell how deep the dent is but a body guy i no fills lil dents with a whole lota primer till it builds up then sand it off and paint
S14toRPS13
If you have no autobody skills, then send it to Maaco.
livinglegend2100
lol maaco....
its cheap. thats for sure..
zach-Ka
Car: 1990 240sx (SR)
Plunger.
livinglegend2100
billy may's pops a' dent. works every time
240sxJoe91
Car: 1991 240sx Ka24de
Lol dent....that's not bad...look at mine ha ha [IMG][/IMG] But i did a temp fix until Christmas break to where i can work on it for more than one day without having to drive it..I don't recommend it but i used a scissor jack...You could do it the old fashion way and use your foot lol...here is my dent currently.. ( until Christmas break then im going to fix it all the way )
[IMG][/IMG] Good luck with it
l2edken
pretty sure you could pop out the inside panel of trunk and get kinda a clear view of that panel, shove that s*** out, for the time being it will look better and maybe it would be a lil easier for bondoin, no screwing holes required
duffman1278
Car: 89 240sx Hatch, the wildcats!
Weld some studs and attach a slide hammer to it. Or oxyacetylene it and slowly pull it out from the inside out.
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
close your eyes and hope it goes away?
AZ89two4Tsx
Overfenders
Nismo-S14
Car: 1995 Nissan 240sx SE S14 sr20det,1991 Nissan 240sx Coupe
the easy way is way is open the trunk get a body hammer and tool call a dolly you get them cheap at a paint store bang the dent till it almost comes out its pretty bad so it wont be perfect buy some cheap bondo fill in the left over dents sand till its smooth keep applying till you think it looks good and if you want to get rid of some left over dents use puddy sand and use spray primer but this is the chep way so it wont be perfect buy the way the edge wont come out that needs to be pulled hope this helps
S13_love
Commas and periods, use them.
But yeah, I think you should have the right idea about now op. Either dent pull it or go at it with a hammer and hope for the best. Followed by applying the body filler, sanding, spraying primer, more sanding, then paint.
Cheapest route is to do this by yourself nonetheless. Good luck.
usdm_anon
Car: 87 supra
you can try the heatgun/hairdryer and keyboard duster method, from what ive seen....aka youtube, it could work.
http://www.youtube.com/watch?v...latedand this one rofl at the endinghttp://www.youtube.com/watch?v=E2Mn3YWIaCg
p.s. i heard it only works in warm weather
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
240sxJoe91 wrote:Lol dent....that's not bad...look at mine ha ha
oh you think that's bad?
but seriously,
sean@z1 wrote:there is not a cheap way you chould pull the dent then hammer the panel with a block till almost straight. Then bondo it and sand and primer and paint
he's exactly right..
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
It won't be too expensive to fix if you do it yourself.
Pick up a set of body hammers and dollys from harbor freight. ($30)Try to get pound out the dent as much as you can. A torch can be very helpfull to get the majority of the dent out by heating the panel before pounding it out. You can try to pound it out without a torch, but be carefull to avoid oil-cans. Hammer off dolly techniques can be used to get most of the dent out. Some hammer on dolly can be used and may be neccesary, however keep it to a mnimum to avoid stretching the metal.
Once you have most of the dent out and the panel has been returned to it's orignal contour, use a metal file over the damaged area. You will be able to see the low/ high spots by the marks the file makes. Tap out the rest of the low spots with the pick end of a body hammer. Use the file again and continue the pick and file untill the panel is damn near straight.
Theres no chance in hell you'll be able to metal finish it, so body filler must be used. Make sure you clean and blow the panel off. After properly mixing the filler/hardener to a uniform color, spread a tight coat of filler over the entire repair area. Make sure there are no holes in the filler because it will result in pinholes that are difficult to sand out.
Once the hardener dries, begin sanding with 40 or 80 grit paper to cut down the rough spots. After 80 grit move to 120 grit. If you start seeing metal show, try to avoid further sandng in that area. After sanding the entire area to as close to contour as possible, gently tap down any metal showing(high spots). You can now apply a thin layer of glaze putty to the entire panel. After that dries continue sanding with 80, 120, 180, then 240 before primer. Make sure to use guide coat during the sanding, it will help you see when the panel is straight.
After priming the panel, wetsand with 600 grit and use guide coat. Then move to 800 or 1000 grit.I won't talk about painting because I'm asuming you"ll just rattle can it.
Good luck!
94_240sx
Car: 94_240SX
This thread is turning into a dent festival. Save up and get overfenders. That's the best way IMO.
24j0hn
Car: 91' 240sx with some babying to be given
is that the 240 that was for sale on craigslist for a while... cuz i remember that pic, thats the for sale pic it showed on the link
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
hbpignosePA wrote:close your eyes and hope it goes away?
That indeed is and will always be the cheapest way out...
Nis-240sx-san
Car: 1991 Nissan 240SX KA-T
I say you buy a band aid sticker, and then put it over the dent. Wait about a week and then peel it off and the dent will DISAPPEAR! amazing!
Shift_Kouki
Car: 95 Nissan 240SX SE
2x4, 5lb sledge, and a rubber mallet... You can also kick it out w/ your foot.
These techniques do require some finesse. Just do it and hope for the best basically.
CrC SIL80
yup i had this car for sale but i guess i need to finish what i started
S13Teddy
Car: R32 Skyline, S13
Turn it into a missle car.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
bring it to a autozone and wait for 2hr. a mexican will ask you in that time if you want that fix for 200bucks
FinkenS14
Car: 1995 Nissan 240sx S14
LMFAO
