96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Fri Apr 18, 2003 10:13 am
Im assuming you have an s14, with a set of cams choked by a short intake open length at high rpms....
As far as I know only JWT makes KA cam gears, and they only offer 2.5 degrees adjustment per notch. Since the gears on the ka are so tiny, the only thing you can do is just add more notches for the pin like they did...
Basically cams dictate how much air/fuel mix can be entered and gasses expelled and for how long, through lift, or downward force on the valve, and duration, how long the valve is open for. Also they determine when the valves open and close relative to the stroke.
Adjustable gears will allow you to adjust when the cams start their process, and the duratin dictates the end relative to the start. It a way to fine tune your cams to get the most out of them. Um will you know what is optimal without a dyno...... nope... If you start out with a crap cam setup and tune it on a dyno, you will get optimum performance from that cam set, but could be less benificial then a non adjusted cam upgrade alone.
As to reaserching first, I say, its your money. To elaborate, do you want to drop lots of coin on different parts, slap them all together, and hope they make power or work together as you would like.? I mean if they dont, and actually counteract one another its only money right?
I prefer to reasearch things alot first, then make purchases and tune knowing that it will help me out. I then will also know that by doing so what the downsides will be. If I can accept the downside of such mod for the increase in performance it offers then I do it. If I cant, I dont see any logic in spending my precious funding on it. Trail and error is rather silly and costly when there are many many many people out there who have led the way and posted their experiance on the matter.
Plus through reading and learning what everything does prior to doing it, you gain knowledge... With that knowledge you can help others down the line... I personally wouldnt like to be someone who just lists name brands installed on the car and when asked what each does goes "I dont know I just buy em and have someone put the stuff on"..
