C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Sep 23, 2003 9:34 pm
I had a small gas leak in may car a while back and some got into the passenger compartment. While I was wiping it up, I was wiping off some of the tar covered areas. A lot of the gas soaked up into the tar and with a rag, it became easy to remove it. Most of it just wiped off. I'd probably not use gas, but I'd expect most solvents would allow you to wipe it off if you let it soak in. You would probably need a lot of rags though. And take care not to smoke around it...
