Whats the best way to get all the grease off from under the car?
newdude1
K well I have had a transmission leak that Im fixing today but there is a lot of grease everywhere. Whats the best way to get the thick layer of junk off from under the car?
Big job, but well-worth the time.
Get that beast up on some jackstands... Cover your driveway with plastic (painter's dropsheets work good).
You're gonna need some protective clothing, goggles and a crapload of degreaser (I like Purple Power the best).
Rent a pressure washer to do it RIGHT.
Soak with Purple Power, get under there with a plastic scraper and start hitting the heavy stuff. Use a long-handled brush (I like the dishwashing brushes for this), and lots of the cleaning solution.
It's gonna be a long job, but a couple rounds of scraping / scrubbing / pressure washing and you'll have an as-new undercarriage.
Don't forget to get under the hood and rinse from the top down as well.
It's really nice to have a clean undercarriage, easier to spot new leaks!
newdude1
Sounds like a summer project :P but I deff will be going this eventually.
s14derrick
Car: 1995 nissan 240sx
if your going to do that maybe now would be a good time to spray on some protectant over any bare metal spots to prevent rust
94_240sx
Car: 94_240SX
I don't even want to think about how much time I spent under the car. I had front engine seal leak for a while, and it was worse than having transmission leak. Mine looks like this now. I used brake cleaner and it worked pretty good. Small toothbrush helps a lot.
Brake cleaner is the best, but it's expensive and requires you to work "quicker".
Wish I could buy it by the gallon!
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Thats one nice looking undercarriage. I hope I can get mine roughly that clean as well. The new parts seem to help aid the eye also
Slappy
Car: 1993 240 sx coupe
newdude1 wrote:K well I have had a transmission leak that Im fixing today but there is a lot of grease everywhere. Whats the best way to get the thick layer of junk off from under the car?
Leave it all there, its called rust prevention. Im 100% serious.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I thank the 1/4" layer of grease in the bay and on everything else for my car being nearly rust free. (battery tray rusted thru and some rust from hatch spoiler)
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Very true.
94_240sx wrote:
See the frame rails and other exposed areas of the under carraige, Those areas are gonna rust fast in the elements. I would spend another few hours under there with a couple cans of undercoating and repray the entire bottom of the car.
94_240sx
Car: 94_240SX
blacksrjdm wrote:
Very true.
Thanks, but I don't drive this car in rainy day. It hasn't seen rain since 1999. Rust is not a big issue down here.
nzmoman
Car: 240sx 2 of em' and always lookin for more
So true.
I have pressure washed at the drive in car wash before and gotten results similar to this.
Matej
Drive through a big puddle.
hazer396
Car: 2007 Tahoe, Impala
Matej wrote:Drive through a big puddle.
ZX88
Car: s13
use your tongue.
Matej
AZhitman wrote:Brake cleaner is the best, but it's expensive and requires you to work "quicker".
You can buy a big drum of it. I bought one a couple years ago for 40$ at Advance Auto/Parts America. I utilize it as a stool to sit on when pondering philosophy in the garage. Maybe I should put it in Super Soakers and have stingy fun with friends.
24j0hn
Car: 91' 240sx with some babying to be given
The very best and easy way is to use GUNK... it comes in a spray can at like pepboys and kragen... all you do is spray the desired cleaning area with a generous amount and let it sit for 10-15 min. then use a bristle brush to give the grime a little persuasion, then wash down with a hose and dry and itll look like new metal!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I'm with the rust prevention guys on this one. Even in Alabama, if I clean the frame rails really well, i.e. remove all the gunk, surface rust shows up. If I leave it greasy, no rust. I like no rust, plus getting all grimy working on the car is fun. it adds to the experience, and friends are less likely to question you about why you didn't show up on time or do whatever it is you were supposed to do.
Stripes
Car: hatch, coupe
I sand blasted mine.
Then I sprayed it with two coats of 3M bed liner.
Slappy
Ever heard of hillbilly under coating? Find a dusty road, loosen your drain plug and gun it. Dust will kick up and the oil spraying underneath will make it stick. Rust free.
Im not saying you should do this.
Stripes wrote:I sand blasted mine.
Badassery.
Well-played, my friend.
