ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri May 07, 2004 1:29 am
I used nothing but B-12(carb cleaner yes...) and WD-40 inside and out. Before spinning the turbo, I made sure I rinsed the whole turbo (oil passages and all) with warm water. Then I drenched everything with WD-40. After that, I poured fresh motor oil into the bearing housing and spun it a for a little while to lube it up again.
