18-20 psi is ideal for a HX35 after looking at the compressor map i would say.HX35's are good for like 245hp at 3000rpms, not 6500, so they would prolly be good for about double that on our engines. and with that, you would prolly be in the High 300's to 400's guessing at around 20psi , but with extra air comes injectors, you would prolly want to upgrade injectors to be in the HX35's efficiency range, because of the higher boost pressure..
well thats a given cause with more power comes higher fueling, so i would say get you some 640cc's and you would be set.
but how much power are you looking for?
EDIT: I see your down in Douglasville, if you ever need any help im just up in Buford. you should prolly also check out
http://www.240atlanta.com if you havent already, some good stuff on there too.
Modified by ZenkiCam at 1:59 AM 1/2/2008
