Whats the best MAF that could go on the SR?
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
So I was wanting to boost my car more than stock and some people have said to put the Z32 MAF on there.
I was wondering if that would be good enough if im running a bigger turbo on 15 punds of boost.
Also what do I have to do to run the Z32 MAF? Do I have to splice wires or should it plug right in. Another thing is that if I do a Z32 MAF do I have to do anything with the ECU?
SpeedRacer1
Car: 1990 240SX, G35
The Z32 MAFS should support about 500 hp. If you think your going to be running more then just get a MAP sensor.
You need to splice in the proper wires AND you need to get a device to compensate for the voltage change. You can either use an SAFC style device, retune the ECU with a ROM, or run a standalone unit.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
so if I were to get an SAFC then a Z32 maf then I could be running allright?
If I cant afford that right now is the stock SR MAF good enough to flow 15psi?
With the setup that I am running I will be at 230 at the wheels Im thinking. I want to get bigger injectors and bigger MAF so that I can have somewere in the range of 300 to 350 wheel powers.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
you know the t25 wont make those powers right
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
buy my z23 n62 maf for $100 and be done
drifter_for_life06
Car: Daily: '16 WRX
Exocet
*hit me up email* [email protected] about the z32 maf
Warped
how about you hit me up if you want [email protected]
or paypal me $100 shipped to [email protected]
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
maby, and yes I know that the t25 wont handle it. I allready got that on lockdown.
Blown240sx
Car: 1996 240sx
If he doesnt buy it Id be interested. Does it have the plug with it and 5 or 6 inch of wire?
Nismo_Freak
Car: 89 Nissan 240SX
Warped wrote:how about you hit me up if you want [email protected]
Your sig is too large.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
No thanks on the MAFS...
