whats the best intake system
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
zocky3
Car: 2005 350Z
i just bought a 2005 350Z, bone stock time to start the fun part, first thing first ofcorse the intake, iv done alittle resarch and found afew by k and n, hks, and afew other brands, anyone have word on witch is the best on the market right now?
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
There is no such thing as the best one out there. They all perform well. The only real difference you are looking at is price. Also if you go with a cai make sure to put in the bypass filter if you have rain in your area. And the JWT popcharger has been known to do well for just being a filter replacement.
Gumby Gone Wild
Car: Z
Personally, I'd go with the JWT pop charger. It's like $100, and gives the car a great sound. Some say they can feel the gain, but you may not. I did not. My next suggestion would be a plenum spacer.
zocky3
Car: 2005 350Z
thanks for the suggestion on intakes,now about these Plenum Spacer's, what do they exactly change or do for the vehicle?
RemixZ
Car: 2003 350z Touring & 1990 300zx NA, Past Sold 1991 NX2000 & 1999 Frontier King Cab
A used one for 1/2 the price. If it looks like crap yet functional, give it little creativity. Anyways I've always uesed Ingen.
orangeNblue
Car: 2008 Nissan 350z
If you don't want to deal with changing filter oil, look into the injen/amsoil dry filters, which can come on the injen intakes by request. You clean them by vacuum and you're still getting a really good product bc its engine.
As far as the spacer goes I would look into the motordyne spacers. The one that seems to get the best reviews is the 5/16" spacer. What this piece does is increases the volume of air and flow through your plenum into the cylinders of the motor...basically more air flow for more power....
BERSERKxZ33
Car: 06' 350Z
i have a 1/2" motordyne spacer and a JWT pop-charger and i can definitely tell a difference over stock
bartZ32tt
Car: 1990 300zx twin turbo, 1996 7.3 powerstroke
Edit: delete
PalmerWMD
Car: 2004 350Z
zocky3 wrote:i just bought a 2005 350Z, bone stock time to start the fun part, first thing first ofcorse the intake, iv done alittle resarch and found afew by k and n, hks, and afew other brands, anyone have word on witch is the best on the market right now?
For the price Plenum Spacers work quite well on earlier Z33's.I may put one on mine soon.
AAM ,Motordyne, are both fine.
Hydrazine
Zocky3,
If you have the REVUP engine keep in mind that the plenum spacer (by itself) does not work on the stock revup lower plenum.
Please see this link for an unbiased and independent test:http://my350z.com/forum/intake....html
If you have the revup engine, use the spacer with the MREV2 for really good results. This is easily the most effective NA bolt on available for the REVUP engine.
If your budget limits you to one or the other (Spacer or MREV2) start with the MREV2. The MREV2 will make great gains by itself and you can always add a spacer later for additional top end HP.
This plot illustrates the basic differences. See plot legend for configuration details.
Return to “350z / 370z Technical”
