Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Nov 12, 2003 9:50 am
JWT ecu only affects WOT or at least 8/10 th throttle up. Ideally one would supply their ecu as there were minor change in each subsequent year. Improvements in the other rpm bands, idle cruise, fine tuning for smoothness, etc.
Since the heads are nearly identical 90-95, other than some reshaping of the intake port, cams and valves identical in shape lift, etc.
The air flow and filling rates should be close, the injectors are the same 370cc/min, so the WOT injector open time should be the same and the plugs are identical so the ignition advance should be the same.
Not to say that each engine is exactly the same but since even JWT leaves some performance on the table for safety. The WOT performance regardless of ecu year should be within say 5%.....say 310-295 HP.........probably closer than that. [307-300].
The fuel injectors are spec at 2% but some may be dirty or out of spec thus the 5%. Different cylinders may get differing air flow from deposits on valves and just plenum imbalances, etc.Differing compression/leak down cylinder to cylinder, etc.
