No, the Bullydogy is very simple and has good instructions. And yes, you can feel and even hear the difference. It makes the car sound more rich and aggressive while giving a lot more power into the mid-high range. Could a better tuner come out that might be able to squeeze out more HP? Sure, but who knows when that will happen. Stillen is supposedly working on one.UltimaCoop wrote:Seems like meth injections not an option since people say u need turbo for that. Do I need to be a pro to use the bullydog tuner and is there any provin gains?
hahaha that was funny i got mad hp thenchow wrote:your next step in performance gain is simple, stickers. Best bang for your buck too! At 1$/ 20HP who needs other mods?
Nico sticker = 25WHPNismo sticker = 50WHPVTEC sticker= ......TURBO sticker = 100 WHP
Turbo sticker probably will cost you $10 or so, so budget wisely!
Honestly, if you think the BD Tuner looks hard to install, Turbo is not for you. I'm not trying to put you down, that's not my point, my point is you have to constantly check/fix things. Not so much with a kit, but even with a kit some things can fail and render your car useless until it's fixed.UltimaCoop wrote:Do we have any Offical kits ? I'm not trying to be a genie pig heh... I heard alot of mix reviews about the tuner too and it looks hard to install
technically, all of your mods voided your warranty. although if the dealership tries to tell you they won't fix your car because of your aftermarket parts, tell them to go read up on the magnussen-moss act of 1975. they can't deny coverage just because an aftermarket part is on there, they have to prove that the failure or break or whatever was a direct result of the aftermarket part. and I guarantee you, if you screw up your ECU you can for sure kiss your warranty goodbye.UltimaCoop wrote:Well I installed every mod on my car so far.... Just when it comes to the ecu I don't want to make any mistAkes ... Now u said you can feel the differnces .... How? Fast accell? Higher top speed? Or just pIn hp gAin.... and does this void my warrarnty
on THAT part and any affected by it. like if you change your tire size to something more than 3% different and you get steering column knock when you hit bumps, its all your fault and you'll have to pay for it. stupid warranty loldownedzephyr wrote:
Bullydog has been around for a while and has made tuners for dozens of vehicles, so they obviously know what they're doing. No matter, though, if something would go wrong with the install, you could be SOL. But.. quite a few people on here have gotten it and none have reported any installations that messed up the ECU.UltimaCoop wrote:Well I installed every mod on my car so far.... Just when it comes to the ecu I don't want to make any mistAkes ... Now u said you can feel the differnces .... How? Fast accell? Higher top speed? Or just pIn hp gAin.... and does this void my warrarnty
The PowerPup dumps your ECU to Flash and then you can go ahead with tuning. A tip to be extra careful is to do the following:nurseryboy wrote:Bullydog has been around for a while and has made tuners for dozens of vehicles, so they obviously know what they're doing. No matter, though, if something would go wrong with the install, you could be SOL. But.. quite a few people on here have gotten it and none have reported any installations that messed up the ECU.
The differences I can feel are mainly in acceleration. The car definitely pulls harder with it. Here's a thread about it:
http://forums.altimas.org/zerothread?id=401362
It's incredibly long though (that's what she said), so you may just want to skip towards the end and read from there, since that's mainly after people have installed it and are giving their thoughts about it.
1. Update your power pup before plugging it into the car.2. One a dump is made of your ECU to your power pup, plug it into your computer and do a backup of the power pup. This saves the dump of your ECU to your PC.3. Go ahead and make changes. It actually does work, quite well.
