Grant@tirerack wrote:Eibach does not list anything for the rear because there should be enough adjustment in the stock range to correct for the drop. Please keep in mind, the Eibach kits are designed to get the car back to stock alignment specs only!
Grant@tirerack wrote:I don't have the stock camber specs at hand here but if you talk to the tech doing your alignment you can have him set it at the negative end of the stock range. That would be a good place to start. They are going to want to align the car after installing the springs anyway and if you are not specific they tend to get it 'somewhere' in the stock range and call it good. Be very specific. You will have to check with the shop or some of the other aftermarket suppliers to see what kind of rear camber kits are out there and what they have had success with as far as setup.
thanks bro. who sells these adjustable upper mounts? ive seen these ones that come under the hood and extend the length of the shock's travel, i want to get those to keep from bottoming them out. do you happen to know who sells those?egan wrote:you can get an adjustable upper mount for your shocks up front, and adjustable rear upper arms in back. this way YOU can set your camber to what you want. i would probably still recommend an alignment first. good luck
