Whats it worth? Part 2
baughb
Car: 1992 Nissan Silvia S13 Converted 240SX
3 Intercoolers2 BOVs1 wastegate springOil catchOil coolerStainlees braided lines 1 thin, 1 thickTurbo and custom manifoldand downpipe (not pictured)Installed in car already are an APEXi S-AFC, APEXi Turbo Timer, Autometer silver faced Boost gauge. And an Apexi Rev Speed Meter.
Former owner said it needed $500 more in turbo-intercooler, intercooler-intake plumbing . He also ****ed up the MAFS and now it pours gas in, which is gass washing the oil. Now theres a slight noise in the engine. So adding the turbo will create greater engine wear. Causing motor to break something, thus needing a rebuild.
***Whats a typical motor rebuild for one of these motors go?*** Cause I'm thinking if i install the turbo just rebuild the engine and add the turbo as it goes back in.
jab11185
Car: 1992 Nissan 240sx
it's worth...one...million dollars......muwahhahahahaa! (couldn't help myself!! )
i got my KA remachined for 435 (checked for cracks, resurfacing, balencing and the like) but they didn't assemble it, just the machine work.....labor will cost you a ton on top of that
as far as boosting it....you could go either way...fiznat built his motor and turboed it from the beginning.....i'm waiting for a 500 mile NA break in before i turbo mine and i'm not going to be running nearly as much boost as he is...it's really comes down to what your comfortable with
hysteria
Car: s13 kat, sv650s, and other projects
the lower costs for a full rebuild (assuming you up the ante a little with forged lower end, and some other things to make the engine stronger) is generally around $1800-$2000 or so... that's what boost designs charges. if you want something more extreme, like what ivan builds, it looks like it goes for $3500-$4000 or so...
Florida240sx
If you still want to sell mani let me know.If you want to turbo just find a low mile ka and turbo it.Then with your current engine have it built.
