you need to tune it buy a shop or yourself, shop preferably.dogma wrote:prepare yourself for the noobness...how can you tell the difference between the two. I've got one purchased from RHDJapan with no box or manuals and it doesn't say what it is just FC PRO and Serial # PFC SR20R 9611-0166 and FCC NT9607-0402 on the commander. Also are these plug and play for a stock setup or does a shop need to tune it when installed. I came across a good deal and I had to buy it so that explains my lack of knowlege. I am trying to do as much research as I can. Thanks!!!!
yeah and you properly install the map sensor then you wont need itnwmrkt wrote:so if you get D Jetro you can remove the MAF? You no longer need it?Thanks
