whats going on with my 1990 q45
anjero84
Car: infiniti q45 990
look i have a problem with my 1990 q45 i was riding home one night and my car just cut off i thought i ran out of gas but that wasnt it i checked the oil and t fluid it wascool.. i tried to start it it took a while then it started it made a loud noise for a sec and then it cut off .. i towed it home and tried again the next day .. i heard a loud ratteling noise but it let me back the car up and move it to another parking spot then it idled down and cut all the way off... then while it was parked i saw a little whit smoke or maybe steam coming out my pipe does anyone have any idea whats going on with my car
qship96
Car: 1996 Infiniti Q45
Broken chain guides?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ever replace your timing chain guides per the article in the sticky at the head of this Forum's page?
If you towed your car with your rear wheels on the road, your transmission is most likely toast also.
anjero84
does anyone know where i can go to get them replaced and how much does it usually cost ? would it be cheaper to get a new engine and no my transmission is fine
96Qowner
Car: 1996 Q45
Any good shop can replace the guides - in the $1000 range.
A replacement engine isn't any cheaper, because you'd still need to replace those guides, added to the cost of installation. And a 94-95 motor with the metal guides has different fuel rails, different harnesses - a pain to do.
You have to get it to a shop for diagnosis, or do it yourself. Manually turn the crank to see if it still rotates freely. Then a compression test. That should tell you if this motor is toast or not.
jimbyjimb
Car: 1992 Infiniti Q45
Step 1 is determining what is actually wrong with the car. Please be more descriptive. Where under the hood, what kind of noise, grinding, whining, crunching, etc... Was the vehicle towed with the rear wheels on the ground? If so for how long? The towing will probably have nothing to do with the noise but towing Q45's with the hiny's on the ground is a major no-no. Says right in the owners manual nobody reads. There are many things that can cause the same exact problems so descriptiveness will go a very long way in helping us help you.
sdkhalsa
Car: 94 Q45 06 M35
This sounds like a problem I had on my 94' Q. A massive leak in one of the injector o-rings caused the engine to burn through a huge amount of fuel. In trying to restart the car there was a nasty grinding sound. I later discovered that the starter drive was totally stripped out. It appears that the problem was not so much hydro-locking as it was the starter having no tolerance for back-firing caused by excessively rich mixture. This happened twice on different occasions. My conclusion is that at the first sign of flooding to pull the fuel pump fuse to blow out the excess. If the problem is hydro-locking, then the safe solution is to pull the plugs and blow out extra fuel. You might note in doing this which cylinder is spitting out the fuel. That is the one(or more than one) where the leak is.
anjero84
so i got my car started then i drove it about 2miles to a shop but the car cut off everytime i turned a corner it would idle all the way down and cut off while riding i had realy no power and the car was still ticking ... when i parked i could see either steam or smoke coming from the bottom of each one of my headers but i couldnt see were it was coming from ... now does this still sound like chain guides ? what else could it be ?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
anjero84 wrote:so i got my car started then i drove it about 2miles to a shop but the car cut off everytime i turned a corner it would idle all the way down and cut off while riding i had realy no power and the car was still ticking ... when i parked i could see either steam or smoke coming from the bottom of each one of my headers but i couldnt see were it was coming from ... now does this still sound like chain guides ? what else could it be ?
You don't need to double post by starting a new thread with the same post!
You do need to post your recent maintenance history and a summary of all you have done to restore your car.
