12er wrote:Depend on what exactly you're looking for...
I would say a S/C.. with a clutch system should do it, however that's only because I've completely removed my A/C and got the space for it.. I mean if it's only for some 5-6psi worth of boost, S/C should be good enough..though it does cause some parasitic drag..And also because I've yet to see a S/C KA24..
however, either one can be made reliable.
Yeah but the drag isn't much more of the engine running the A/C. Use a MB 230 blower,it fits perfectly in that space and is a clutch type blowe good for up to and over 22psi. YES 22psi from a blower! If I end up keeping the KA thats what I'm doing,the KA is all about mid-range and torque,and with a clutch-type blower you could still hold boost to redline.
