whats a good rear end to use for highway
240drfter
Car: 1990 240sx hatchback rb25det(sold without motor)
1993 vert built rb25det he351cw (for now) in progress
have an rb25det in a s13 had j30 in....broke crossmember in two..have another stock rear end in now i'm going to swap the j30 back in but i was just wondering about some other rear end options to make it cruise around 70mph a little easier. right now its like 2800-3000 at 65-70. i heard about a skyline rear end with j30 output shafts but whats the gear ratio differences between all these rear ends... any help will be appreciated
BoostFab
Car: S13cp, S13fb, S14z
i have a 1997 q45 rear-end that is 3.6 final drive. so you will definitely get higher top speed. it will swap in using the j30 output shaft. let me know.
240drfter
is it a lsd unit also.....what ratio is the j30 for comparison
BoostFab
240drfter wrote:is it a lsd unit also.....what ratio is the j30 for comparison
yes it's lsd, the j30 gear is 3.96
Shocker
Car: 89 240sxHB rb26/30
BoostFab wrote:i have a 1997 q45 rear-end that is 3.6 final drive. so you will definitely get higher top speed. it will swap in using the j30 output shaft. let me know.
How do you like that rear end ratio? Car fall on its face at all or come out of boost on you?
240drfter
how much you want for it
turbo2nr
Car: 97 240sx (kouki)
q45 = 3.69 gears same as the 350z/g35beefier axels and input shaft
thats my choice, i <3 long gears and big turbo
BoostFab
the longer gear allows you to stay in boost longer and higher speed top speed.
240drfter wrote:how much you want for it
$100+shipping. i was told you will need to get the 95-97 j30 diff output shaft for it though to use your stock axles..
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
im using a n/a 90 gts vlsd rear end, its got 2.90 gears, i love top speed
RB26needaparachute
Car: 1998 240sx Se/RB26
I have a Tomei 2 way "clutch type" lsd and its great,it is noisy sometimes though..
BoostFab
SullivanRacing06 wrote:im using a n/a 90 gts vlsd rear end, its got 2.90 gears, i love top speed
on take off, i can beat you running on my feet LOL
raremotive
Car: 04 Infiniti G35
BoostFab wrote: on take off, i can beat you running on my feet LOL
Haha, seriously.
