Whats a good KA-t kit?
ForsakenTH
Car: Nissan S14 Zenki
ive been bouncing with ideas of SR or KA for a while and the thing i like about the KA-t is that it seems less expensive. Ever sence I got into the 240, i always figured i would get a SR but now that i have my car and it only has 72K miles on it the KA ideas has been in the back of my mind.
ive been looking at the Greddy kit, but i saw the ssautochrome one on ebay for like 600 bucks...does ssautochrome make good set ups....is the greddy kit worth the money for.
this is the ssac kit i was looking at on ebayhttp://cgi.ebay.com/ebaymotors...%3AIT
would that be a better buy then the greddy kit?
Zetec
Have you looked at the boost designs kit? SSautochrome stuff is cheap knock off type stuff that is made in china which is why it is so cheap, it may work good at first but i wouldnt trust it to last too long. The boost designs kit seems to be the best price on the market. Phatka-t.com also has a very nice kit on the expensive side of things though but i believe you get an aem ems with it.
ForsakenTH
thanx for the heads up...ya i have looked at the boost desins kit. i like everything about it but the intercooler...to me it looks kinda small. i know PJ is on nico...can you order the Stage one kit just withough the intercooler?
WDRacing
I'm sure PJ will be able to make custom orders, but his intercooler really isn't to small at all. I've made over 300 whp with only a sidemount IC before. The FMIC with BD's kit will be plenty good for 400 easy. At which point your going beyond the Stg 1 kit anyway.
WD
slide240slide
Car: 1991 Nissan 240SX KA motor 5-speed
definately do it up right im going to go with Boostdesigns stage 3 and a AEM EMS as soon as i sell my Truck!
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
There are about 5 companies out there that make a COMPLETE turbo kit for the ka motor. The only thing is, none of them has the perfect kit. Some kits have better turbo's, other kits have not so good turbo's. Same with the manifolds, some use cheap crap manifold and others use a better design manifold...And most of them run the same crappy fuel management setup. It works, but if ur gonna do it, do it the proper way, not a bandaid route. You migt be better off just buying some parts from this company and other parts from another company. Then u may have to custom build around both for them to work together...But its ur decision..
nr2134
Check out http://www.phatka-t.comThats the kit I will be running.
BobWithBoobs
Car: 89 couple with s14 dohc swap.
rn240sx wrote:There are about 5 companies out there that make a COMPLETE turbo kit for the ka motor. The only thing is, none of them has the perfect kit. Some kits have better turbo's, other kits have not so good turbo's. Same with the manifolds, some use cheap crap manifold and others use a better design manifold...And most of them run the same crappy fuel management setup. It works, but if ur gonna do it, do it the proper way, not a bandaid route. You migt be better off just buying some parts from this company and other parts from another company. Then u may have to custom build around both for them to work together...But its ur decision..
What would YOU sugest for a turbo settup... lets say you want to have around 325-400 hp with t3\t04e What brand would you advise??? and what parts?? what manifolds??? lets your lift . Would help us all
AustinSilvia
Car: CARS, nissans sr20det ftw!
use the search button...
oncore134
Car: 96 S14
Does anyone know where i can get a Downpipe for a ka24det that will have a wastegate hookup? i need one asap.
rn240sx
09 Ninja 650R
06 Suzuki S40
Those downpipes are not a universal fit. Each one is custom made for the turbo and manifold setup. What turbo and manifold r u using..??
