Whats a good brand aftermarket clutch kit for 1985 720 truck
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
808countryside
Car: 1985 Nissan 720 king cab pickup
I wanted to know whats a good performance clutch kit for my truck... i want to be able to lay some rubber while shifting from 1st to 2nd or even from 2nd to 3rd. my stock clutch aint cutting it for me. let me know thanks!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Are you sure its your clutch? I like exedy.
you should SR20 swap and then you can lay rubber all day.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
breadbox wrote:Are you sure its your clutch? I like exedy.
Yeah these engines lack the power to shift between gears. SR, RB, CA would give you what you're looking for.
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
I like exedy as well. Good luck "laying rubber", I can only barely chirp mine. But mine is a workhorse instead of a hotrod. I do that in one of the Z's :naughty:
fastboatman29212
Car: left this forum. Sold my truck.
Post some helpful pics of your clutch install. I'm gonna do mine soon. My clutch is slipping under even small loads ( like pulling my John boat and trailer outa the water). :chuckle:
breadbox
89 Koop
84 720 4x4KC
I bet Vinny's 720s chirp tires.
Also I have started pieceing together an RB20det swap for my daily, so I'll keep you guys up on that as well. I want to put a 4wd rb in a 720 but that will probably be way down the line from now, but I am starting to dabble in inline 6's.
lukemeiers
Car: Datsun B720
I used a Carquest one that worked just fine.
flinterman2000
Exedy for aftermarket.
Return to “Datsun 720”
